storing a preset in the computer
hello everybody
i will be very very happy if someone tells me how to store a single preset i made in the computer. i am working with cubase and would like to store all the presets of a project in the folder of this project
thanks a lot
If you are on the latest OS version:
  • connect the Voyager’s midi out to your computer’s midi in.
  • In Cubase be sure to activate receiving and sending of Midi SysEx data. This is normally switched of in Cubase by default.
  • Voyager: MASTER menue item 3.2 “Send Presets”.
  • Select patch to be send
  • press OK after you activate the recording of SysEx in Cubase
  • Done !
To send the sounds back into the Voyager be sure to set item 3.3 in the MASTER menu “SysEx enabled” to enabled.
And be sure to set your Voyager to the SysEx ID #1 in MASTER menue item 3.4 “SysEx Device ID” unless you own several Voyagers.
thanks Till, it makes me happy you suspect me of having few voyagers. i only got my first one few days ago.
this is the king of toys
