So, I just tried an idea that worked out very well.
Patched the CV Out (pitch) from a BeatStep to the CV In of a Minifooger MF-Drive and set the knobs so the filter opens more with higher pitch signals. Poor Man’s MIDIMurf and possibly one that is more powerful in the end (more patterns, real time step changes, etc.)
Now I’m wondering what I can do with the MF-Ring, and especially what I can do with the MF-Delay (much craziness).
^That’s cool! I am not getting as much resonance from the MF-Drive (to be expected), but it works similarly.
Most of what I do with the MF-Ring is to use it as a “Second OSC” for the MicroBrute. This works because I can send Pitch CV to the MF-Ring and achieve keyboard tracking of the overtones. It really helps make the single OSC sound much more complex.
Just wish those darned BeatSteps would sync to incoming MIDI clock OTB.
Maybe we can start a thread dedicated to toneprints for the hall of fame/trinity/t2 since they are interchangeable. Every Moog needs a reverb, and not every Moog can have a bigsky or h9.
I have used the TonePrint Editor a lot with the Flashback Delay.
Among the things you can edit on a single Flashback TonePrint:
Delay Time
Feedback
Saturation
Feedback High Cut
Feedback Low Cut
Output Level
Dynamic Delay Sensitivity
Damping
Release Time
Reverse Delay Time
Modulation Type
(Classic Chorus, Adv. Chorus, Classic Flange,
Adv. Flanger, Vibrato, Vibrato Ramp, Tri Chorus,
Tri Chorus Altn, Through Zero Flanger)
Modulation Speed
Depth 1
Depth 2
Depth 3
Hi Cut
Mix
Output Level
Delay Time 1
Delay Time 2
Delay Time 3
Feedback
Feedback High Cut
Plus, both the DELAY and FEEDBACK knobs can each be reassigned to simultaneously control up to three of the above parameters. And each of those three assignments can have their own separate response curve that can be graphically dragged on the editor.
Here are some examples of what the Flashback sounds like on Moogs:
To be clear, the TC Electronic Flashback is what I use when I’m looking for repeats that are basically exact copies of the original signal, delayed in time, alternating from hard left to hard right, and quieter with each repeat (no tonal changes).
I own two MF-104Ms and an MF-104MSD for when I want to “play” a delay by massaging the Delay TIME and FEEDBACK knobs.
Would that be the standard Flashback, or Flashback Triple Delay? Also, do you have to attenuate the signal in any way / do you experience any nasty signal overload issues? Just wanted a little more info before I add it to the list on page 1 of this thread.
I tried out the Hall of Fame reverb yesterday with my voyager and my modular. No signal level issues whatsoever. In fact, it sounded so good, I ordered another TC reverb so they wouldn’t have to share.
I know everyone loves strymon stuff, but for the money, there is no better reverb pedal than the TC options.
excellent feedback. the first post has been updated.
personally, I’m a huge fan of Strymon both because of their products and their corporate culture. They actually communicate with you on Instagram, as opposed to simply posting up a bunch of crap designed to generate likes and followers and such. I’m definitely a fan.
Curious if any of the folks here on the retailing side have had a drive by sound check of the new Strymon Euro “GENERLISSIMO”. We realize its set for summer release, but thought folks would be kicking the tires by now. Between the General and the Mother, we are presented with more knobs and switches then there are in a cockpit of a Boeing Dreamliner. Folks are going need a pilots license to operate these on stage. Time for my mind to fly the friendly skys!!!
I’ve heard amazing things about strymon stuff. On a related note, I got a tech support response from TC electronic back in less than 4 hours, and I sent it during the day, central standard time. They are in Norway. Must have been working the night shift.
Yeah, Eventide is awesome, too. They replaced one of my Space pedals when it was on the fritz. No questions asked, they sent me the return box and stuff, then sent me a new one. They took my call and hooked it up.
I just got my EHX Bass Soul Food overdrive. It really is as transparent as they say it is. Sounds great for basic overdrive (as opposed to fuzz or distortion) and keeps as much of your original tone without getting muddy. It has a blend knob, which is essential for synths, and a “treble” knob which is kind of like a high pass filter, but it only effects the overdriven portion of the dry/wet mix. And for $80, it’s kind of a no-brainer. I would say putting one of these, and the BBE Sonic Stomp (around $65) on every synth in your studio wouldn’t be overkill. Obviously you would use it on every synth every time, but I’ve yet to make it sound bad, and it always sounds beefy.
