I notice some stepping occurs when tweaking parameters, what is the reason for this?
I tried turning off parameter display
is MIDI connected?
yeah, sure
Im using it with Live 8.02
Then you should switch off the local controls.
If your local controls are already off the reason is the serial transfer of data.
The MIDI transfer needs much more time than the internal circuit of the Voyager and this means turning a pot sends a lot of MIDI data and it’s not possible to transfer each new pot value via MIDI.
aha, that make sense, I try this, thank you!
