SS 37 CV Osc 1 wave pot problem
The wave selection pot on Osc 1 doesn’t respond until it hits nearly the 5th mark on the dial, but also fails to adjust the square wave pulse width as much as Osc 2. Anyone else having this issue?
Hi umami,
It sounds like you may need to run a pot calibration. This is a fairly simple process that only requires you to send sysex files to the instrument.
Instructions and pot calibration files can be found here: https://www.dropbox.com/s/ai4ko7cg0tns940/POT%20CAL.zip?dl=0
Done and done–seems to have improved the situation. Thanks.
