Hi all,
I am having issues with the latest version of Sub Phatty Editor ‘VI’ (v1.1.0) under SONAR Platinum. The earlier version VI used loads under SONAR, but the new versions fail to load or fail the VST Scan. I would love to use 1.1.0 with the fixed ‘Midi Channel other 1’ bugs because I prefer to use Channel 4 for me SP.
More details…
Sub Phatty Editor Release 1.0.3
Sub Phatty Editor-VI(x64).dll - Working in Sonar, but automation only works when SP set to Midi Channel 1
Sub Phatty Editor(x64).dll - Working in Sonar, but automation only works when SP set to Midi Channel 1
MIDI forwarding does not work - when ‘MIDI Out’ of the plugin is enabled in
Sonar, playing keys on SP do not appear to be received by Sonar.
Sub Phatty Editor-VI(x86).dll - Working in Sonar, but automation not supported (VST Bridge Limitation)
Sub Phatty Editor(x86) - Working in Sonar, but automation not supported (VST Bridge Limitation)
Sub Phatty Editor Release 1.1.0
Sub Phatty Editor-VI(x64).dll - Will not load in Sonar. The plugin manager tries to scan it, but something fails.
Sub Phatty Editor(x64).dll - Working in Sonar. Automation works whatever Midi Channel the SP is set to.
Sonar, playing keys on SP do not appeart to be received by Sonar.
Sub Phatty Editor-VI(x86).dll - Will not load in Sonar. The plugin manager tries to scan it, but something fails.
So it appears there is something broken in newer VI from the previous VI.
Regards,
Chris
