I am experiencing a bug in release candidate 2.1.12
The LFO dissapears as I play notes above C6, when LFO KB Amount is being used. If this value is set to zero it works fine. But, when it goes beyond 12’30 o’clock, the upper notes’ LFO goes away.
As you move the KB AMT higher, more notes are affected. If the value is maxed, then every note from C6 and higher are not modulated by the LFO anymore.
This only happens when you press a new key. If you move the LFO KB AMT while the note is being held, it works, until you lift your finger and press the same key again.
I hope I made myself clear, I am not a native english speaker so its quite hard for me, even though I’ve been studying the language for more than 35 years
