I just found another source of unwanted clicks. If this is not particular to my specific Muse, you should be able to reproduce easily:
Initial patch, turn down the filter for a very soft sound (will enable you to easily hear the clicks.) On Pitch LFO, turn Shape fully CCW, and press the Envelope button so it lights up. (But nothing should be modulated by the LFO.) Now listen to the clicks on note on. Turn off the Envelope button on Pitch LFO and no clicks (as it should be).
I made a little video to show it:
(Video is unlisted, so as of now it is only visible from here.)
This clicky bug (as I believe it is) is not a big deal for me, because it can easily be dealt with, but the important part is to know it, because otherwise it might drive you crazy if you start hearing clicks and you have no idea what is making them.
I guess you can say the rule is: NEVER have the Pitch LFO set to Envelope, unless you are actively using it in that function.
