SP USB midi out problem
Now that i’ve had the sp a while I’ve noticed that occasionally the midi out on the USB stops working. The unit still responds to midi in sent from the daw but no longer sends midi, this is a huge issue if local control is off. Restarting the daw/sp fixes this but is not a great solution.
Any ideas?
(temporary) try choosing “master reboot” from the system utilities menu, see if that works without you needing to restart the DAW
(less temporary) I have an update for the USB firmware, which could potentially also help.
for now I only have an installer for PC, we’re working on one for Mac now. you can email me (amos at moogmusic d0t com) for more info
