Sound only on 5th key press!
Hi all,
I updated the firmware to 1.2 last night because my editor never works and I thought that might solve the problem. Well, now my Sub 37 will only make a sound every 5th key press. The other 4 presses no sound, then sound on the 5th. I’ve uploaded the 1.2 firmware four times now and still have the same issue. Thanks.
I solved it. I reset Global and MIDI setting to their factory default. That seem to fix it!
Good to hear that your issue has resolved, but the initial post got me to thinking: What in the world would ever cause that symptom to begin with? Consistent “delay” in processing “note on” event – I’m not a programmer by any stretch, but perhaps the more knowledgeable can weigh in.
Not sure what instrument you are talking about, but this could be a polychain setting “n of 5” :wink:
