Sound and panel not updated
Do not know if this is a new features.
When I have a preset with a long release and switch to another preset, The sound from the first preset remains till the release is ending. Also the panel is not updated till release end.
Pressing a key on the Sub 37, the sound change immediately and the panel get his update.
Sub is not connected with USB or Midi.
Also a preset with long release changing in INIT has this “feature”
See video.
https://youtu.be/yyIG-0Hog-U
Latest Firmware and Editor.
Luloop is greeting you.
It has always delayed changing the sound during a long release - this was a feature originally requested by live performers who wanted to be able to end a song on a long release and set up for the next song (change preset) without cutting off the end of the releasing note.
There is a small change recently: It used to be that you always had to play a key, in this delayed-preset-change case, before the next sound would load. In the new firmware, it monitors the VCA level and switches automatically to the next sound when the Amp EG level gets low enough.
(in fact I’m thinking I could fine-tune this to switch a little sooner; seems the audio is already silent for a bit, before it automatically switches now.)
So, this is an existing feature… is it OK?
Hi Amos,
Yes it is a great feature..I did not notice.
Works fine. To fine-tune this to switch a little sooner is of course pending on the preset with a long release.
I think it is ok like it is now.
Little surprises are always welcome.
Thanks Amos.
Wish you all the best.
Greetings Luloop
