[Solved] Subsequent 37 - Disable Arpeggiator MIDI output
Today is a joyful day, for my synth has arrived!
I am just getting started, but one problem I can’t seem to solve: I use the Subsequent 37 as a controller for my DAW, but also as an external device from my DAW to send MIDI notes to it. Now when using the arpeggiator (being triggered from a MIDI lane in the DAW), the sent notes create an arpeggio, the notes of which are being sent back into the DAW, which messes up everything.
In the manual / menu I found:
MIDI Menu → Out Filters
Global Menu → Local Control
both of which seem somewhat related to my problem, but no option does what I’m looking for. My workaround right now is to deselect the track in the DAW, but it’s somewhat tedious.
Sidenote: I am not using the Moog Editor Plugin, but Reasons “External MIDI Instrument” device. Perhabs the problem can be solved with the editor?
I found the solution:
In “Global” menu, there is a submenu “Seq Options”, which contains “MIDI Output”. I needed to set this to “Keys”
