SOLVED: 0.9.33 Some of the buttons do not work
Using the Plug-in with Ableton Live 9.5 on Mac, some of the buttons on the synth does not work - they work in the plugin and turns the buttons on and off in the synth but not the other way.
  • Sync buttons in LFO 1 and 2, and EG Envelope and filter envelope
  • Loop, latch on in both envelopes
  • Mix on off buttons
The plug-in does not indicating receiving input when pressing these buttons either. So does the firmware transmit them?
UPDATE: After fiddling around a bit - suddenly the buttons work again. I have not restarted Live, the Synth or reloaded the plug-in. Is there a intermittent issue?
kr
Morten
Are you connected via USB or DIN ? Can you delete preferences, restore to defaults and try again. We’re still investigating similar reports, but it would be interesting to know if it puts the system to a stable state.
Thanks.
It seems to work now with the 0.9.39 and 1.1.19 release. Don’t think it worked with the 1.1-17 FW. Works both with settings to CC or NRPN
Nice
Great ! Thanks for checking this out.
It works now - no way to change subject of original post to “FIXED” so it was easier to see?
Not sure. As if FIXED appear in the title the report will be probably ignored. It’s always good to have more feedback from more users.
