I’ve noticed that when using the VST version of the Sub37 Editor that the Sequencer Clock Divisions don’t show up like they should. I was trying to automate the Seq Clock Divisions from 1/8T to 16th. No matter where I placed the hardware knob 1/8T wouldn’t show up in the vst editor. I even scanned thru the list, turning the knob as slow as I could. In the hardware list it is between 1/16. and 1/16 but when you turn the knob on the hardware while watching the vst editor 1/8t never shows up. So I had to record the automation from the editor. It worked fine but why isn’t the 1/8t setting showing up in the vst editor when automating from the hardware? I like to automate from the hardware, not drawing in lines or dots. The stand alone version doesn’t exhibit this behavior, it shows the 1/8t setting as it should when turning the HW knob.
The USB noise. Almost 10db of additional noise is present when the usb connection is connected. The noise floor hovers right around -80 db with no usb connection. I can actually hear it through the cans as well. I’ve been painstakingly trying to remember to disconnect the usb before committing to exports as audio. Is this normal or is this something with my setup? The usb cable maybe? Maybe it is too close to some power cables or something? The noise reacts when I move or resize the vst editor. It changes in tone.
Thanks for any info you might be able to provide.
