Slim White Noise
Hello all, I was wondering if you could guide me to creating some White Noise on the Slim Phatty. I want to be able to save it as a preset.
How are you all liking the Slim?
hey ho,
white noise is even there in a factory preset called “hold4fizz”.
check the advanced preset menu for that preset, and you’ll find it there noise as a mod.source.
(and RTFM :slight_smile: p.36. :smiley:)
you could also plug in a sw radio into the audio-in and plug a dummy patch cable into the KB GATE :slight_smile:
noise in the phatty internally is only available as a modulation source, not as a raw waveform.
the only way to patch a white noise as a raw waveform is from an external source.
http://www.moogmusic.com/forum/viewtopic.php?f=7&t=11579
Thanks guys,
I’ll give it all a try. For on the fly, live situations, I’ll probably use the “Hold4Fizz” preset and modify it a bit before I save it.
Cheers
I just ordered this board and all of the components thru Jameco: http://www.musicfromouterspace.com/index.php?MAINTAB=SYNTHDIY&PROJARG=NOISECORNREV01/NOISECORNREV01.php&VPW=1366&VPH=547 Everything was about $58. I have a kickass little metal project box that I have been waiting to put something into, this will probably fit perfectly.
Guessing it will really add some depth to my LP. As soon as I get it built and tested, I’ll post some samples.
Check out this topic where I explained a white noise trick I use to get white noise on the LP or SP:
I use the CP-251’s noise source through the Slim Phatty’s audio input. Works great!
