Hi all,
I notice that my Slim Phatty stops sending MIDI CC from the knobs after a while. I got the latest firmware installed 3.21 690/34 and use the synth via DIN MIDI.
I got to turn off the synth and turn it on again but after a while it stops sending MIDI CC which is really annoying.
Anyone knows how to solve this issue.
Thank you so much in advance.
Alex
Do you have anything sending midi TO the SP which might contain a local off message?
I use my Little Phatty and Slim Phattys (aka: Phatt Bastard)all via DIN only. I’ve found having the USB active is a problem. I have my MIDI ports set to DIN and Merge set to NONE.
If I have to use USB for some reason I can always plug the cable in and switch the port on.
I don’t know if this will help with your problem but in my experience with Phattys and the Sub37, USB MIDI is an area where Moog is particularly weak and sometimes its problems bleed over to the DIN port.
