Yesterday arrived my first analog synth! The Slim Phatty! Superb sound, superb analog…
but i’ve a curious problem (maybe I’m inexpert and this isn’t a real problems; I simply set it better
My Slim Phatty have this feautures:
Boot V. 1.1
Vers. 3.11 674/31
I command the slim phatty via Korg R3 (a VA synth)… Midi OUT KorgR3 -------> Midi IN Slim Phatty… all right !
When I turn on, the SP is ok, I press various keys of 'R3 and SP works very gooooood!
But after a random time, when I press a key and I leave it, the sound continues (as if the Release of the volume is set to the maximum)…
…If i change preset the sound continues (with max Release) in the new sound…If i press an other key the sound change with new key but if I leave it, come back the previous key (clearly with the same long volume release)…PS: if I move the Sustain Volume (Env. Gen.) to zero the sound stop but if move again to the right, the sound clearly go up (withour re-press the key) and never finish _
…seems that there is always a key pressed !
PS: the situation start randomly affecting all types of presets without distinctions..it is “clearly” in sounds with long sustain or release (like a “pad” sound); the situation is similar in short sound like a lead: if i press an other key and i leave it, start (for a short period in this situation) the old key I pressed…as if there was always a key pressed…ufff…
The only way to solve this problem, at the moment is press 2 times the “Value” knob on the SP (1 time: start the arpeggio, 2 time: come back to Preset Active and release stop)…but after a random time, the problem is repeated !
The keys of R3 are clean and working perfectly (In fact, the sounds of R3 does not have this type of problem and if I try to play some VST this problem is not exist)…The problem that i explain, can happen also with the Piano Roll of Logic Pro 9 (if I press the keys of the Piano Roll in Logic with my mouse when I command the Slim Phatty via Logic )…maybe it’s a particular setting of the Slim Phatty? there is a way to solve this problem?
Sorry for my bad english…I hope to find here the solution !
Lorenzo
