Not available for the Slim; never has been AFAIK.
A CV kit would need to be custom designed for the Slim (the one from the the LP wouldn’t fit the Slim’s case).
Thanks for that.
I understand that there’s some kind of ‘kit’ available.
If I could get that, but without the fittings that wouldn’t fit the Slim then
it would be easy enough to diy the output sockets.
(and if there wasn’t space for 1/4ins sockets, then there’s bound to be room for 1/8in ones)
What I don’t know is whether the electronics in the Slim is compatible with such an idea.
Moog now tell me the Slim doesn’t have the option because of size restrictions.
hmm, using an external midi device would give me
Pitch Out
Gate Out
(and for the Kenton, an additional LFO)
So that would indeed help.
…but not the Envelopes.
I do have a Doepfer Dark Energy, (about same size as the Kenton) which has a midi>CV.
I could run it in parallel, although temptation would be to do without the Slim altogether.
yes it’s technically possible to tap into the CV signals on a Slim Phatty. It would be a delicate job for a skilled tech with access to schematics, and would require a lot of soldering wires directly to surface-mount components. Basically I’d describe it as a similar difficulty level to chip-modding an old Playstation/PS2. which I have done and it was annoying and difficult… but successful…
Hi Amos, thanks for the reply.
I have a technician who could do that ( possibly myself).
So the problem would be the schematic.
(how long before the Slim becomes ‘legacy’
I’ve used the official UK Moog repair people before, I assume they could do this if they wanted (?).
…but as they charged well over $100 to replace a voltage regulator !
Maybe I should ask them for a quote.
I asked my local (Belgium) Moog service point to install the Little Phatty CV out mod, and their quote was a tad under 600 USD. So… good luck with that
Given the likely high cost and hassle of getting the Slim modified, and if you don’t want to use your Dark Energy, why not get a Doepfer Dark Link? According to Doepfer site, it is the same interface as used in the Dark Energy. I don’r know where you are, but in USA, the price is around $170. I would think that would give you more flexibility in the long run, as a stand alone unit, nit tied to the SP.
