Slightly different sized DC plugs compared to normal
I’ve bought a T-rex Chameleon power supply to avoid five wall warts. Problem is that the polarity reverse adapters don’t fit that well, their annoyingly easy to unplug by accident. There’s something about the size that isn’t right.
Anyone else that has exprienced the same thing and if so, how did you solve it?
I just put all 14 of my wall warts into a box with a number of power strips and have only one power lead coming out as well as the 14 DC leads. Makes life simple (except for the box that I have to lug around…)
Stephen
Did my homework and realised the plugs need to be 2,1 mm on the inside instead of 2,5. And a little longer. Bought the plugs and will solder the chords soon. Must do the trick.
Nice. Though I need to work with less space and portability.
