Simple MIDI question
Brand new Moog user…waiting on my LP, should be here next week! Quick question: Can the LP be used to control a soft synth such as Reason? If so is there any set up to do this or is it fairly straightforward? Thanks for the help! i have already learned a lot from this forum anticipating the arrival of the LP!
sure, it is possible. you just have to match the midichannels on which the mood is sending to which your application, like reason, is receiving. then switch to “local off” on the moog so it does not sound while you want your software to sound and there you go… :wink:
thanks! i am sure it will be make sense when i get the LP in front of me.
