Shift Knob
Hi!
Is anybody here to explain what the Shift Knob is use to me? I find no relevant function for the part, used that anyone of you?
I know how it works, but I have no use for it.
If Moog not know which key they should take to show parameter values in the display, then I would take the Shift Knob;-)
ciao
Mick
KNOB SHIFT is very usefully. I like the extra parameters.
Just play around with it and maybe you should read the Manuel. Starting @ page 30
You find it here
http://www.moogmusic.com/sites/default/files/SUB_37_MANUAL_v1.1_0.pdf
good luck
Regards Luloop
Is anybody here to explain what the Shift Knob is use to me? I find no relevant function for the part, used that anyone of you? I know how it works, but I have no use for it.
I agree with LuLoop.
I guess if you have no need for a delay time in front of the envelope, or a hold segment at the peak of an envelope, or the ability to make the envelope depth velocity sensitive, or the envelope times pitch sensitive, then you are correct – the shift knob is of no use to you.
But I sure like it! :smiley:
