I’m wondering if I can get some help from the group. I’ve got a mixer, moogerfooger, airsynth, and 3 Mother 32’s. What’s the best way to hook everything up?
Hi Erick,
I’d use the 1/4" from the back of two of the M-32s to the 3 & 4 mono inputs of the mixer.
I’d connect the third M-32 to the input of the MF-103 with its stereo outs going to 7 & 8 of the mixer.
Then I’d send the Air Synth to 11/12.
Now, each of those can get whatever Delay/Reverb effect you choose on the mixer, and all the LEVEL knobs are on the bottom row.
The beauty of using the outputs on the back of the M-32s is that the 3.5mm VCA output jacks are still free to use as you please.
(Alternatively, you could use the FX SEND to go to the MF-103 and its stereo outs to mixer inputs 5 & 6, but you probably wouldn’t want the same phase effect on all the instruments that are using the built in effects.)
Hope that helps.
