Hey guys, noob question, but how do you set the mod wheel mods so that its always on? Been trying to find it in the menu but can’t seem to track it down. Thanks
Use the 'Pedal/On" buss instead. Then the amount knob isn’t affected by the wheel.
Great! Appreciate it.
Then you have to reset the amount every time you change a preset unless there are global settings that I don’t know about.
Ah, just checked it out. I’d like to use both Mod Busses. The issue is I have the Novation Remote SL (gorgeous), but the mod wheel is the joystick type that has a default down position held by elastic resistance (is that the correct description).
So I’d simply like to set the amount to always up/on so I can take advantage of both Mod Busses.
Sure I’m just missing something.
Think I got it, going to test tomorrow morning when I get to the studio, just need to set the “Shaping” to “On/PGM”. Then set a front panel control to control it. Hope that does the trick.
