This maybe a dumb question Where is the serial number located on the Little Phatty (Stage II) ?
On the Stage l it’s located on the back. I’m not sure where it’s located on the Stage ll..
Look for a really small metallic sticker on the back.
I had trouble finding mine at first, too. ![]()
It isn’t that small is it? ![]()
Not really, but I was expecting it to be somewhat noticeable. It’s not. It’s on the left-hand side, opposite the side with the power switch and inputs.
Maskin, I am used to such numbers being on the bottom or on or near the warning sticker, so when it wasn’t on either of those places, I looked to the left and hit my forehead with my hand. ![]()
It’s written on my boxes too so there is no way to miss it. ![]()
Wasn’t on my box…I looked for it there first. ![]()
Hypemaster_herb, did you find it?
Thanks for the replies.
I still haven’t found the serial. I even checked the box.
Heres a pic of the back of my LP. I don’t see anything on the left side.
Left if you stand in front of it…so right from the back… ![]()
Btw…what is that metallic sticker doing there… ![]()
Last time I checked …
“100-240 VAC
50 - 60 HZ”
Isn’t a serial number.
I guess it should be located on the left side from the back.. Seems like you don’t have a serial number. ![]()
Here’s the back of one of mine:
Thanks. This kinda sucks because, I got my little phatty during the promotion for the free CP-251 and I need the serial number of the LP for the paper work to get the CP.
That’s a bummer! I’m trying to think of other ways to find the serial number but I can’t come up with something..
I believe the date of purchase on the receipt is the most important part for the CP-251 deal. The Serial # is perhaps needed to avoid sending multiples (NO, NOT MULTIPEDALS). Contact Moog and they should be able to square things away and send you that missing #/sticker (is so desired).
