is it possible to use Logic to sequence a model d using the mp201?
It should be able to handle that.
You could probably modify preset #27 to take the incoming MIDI messages from Logic and output the corresponding CV’s.
Playing a Model D using Logic or Sonar through an MP-201 would be a really great demo of the power of the 201.
thanks for the reply. I seem to have trouble getting a s-trig to function correctly. What settings do I need to adjust to get the gate out to s-trig to function correctly?
Maybe this will help.
http://www.synthesizers.com/gates.html
http://www.synthesizers.com/moog_trigger-convert.jpg
Apparently synth.com sells a cable for this purpose too.
http://www.synthesizers.com/cables.html Scroll to the bottom to see the cable. You might try contacting synth.com for verification this solution works for the Model D.
So what’s up? What happened here? I’m wondering if I could do this too!
I’ve been researching is all over the web, & I’m gathering that this is not possible because an s-trig needs a higher voltage to open the envelope of the model d, and the mp201 is not equipped for this.
Am I correct in this? Amos? Anyone in the know here?
There are devices that ARE equipped for is like the doepfer mcv4, Kenton pro-solo, etc. I was hoping to sort of get 2 birds with 1 stone on this…while I’m spending the money, why not get a piece that can work with the model d as well as the cv’s of my foogers, minimoog & other synths…
If the voltage is not high enough, boost it.
