Sequencing a beat on one mother only
https://www.youtube.com/watch?v=af7E4Zj5_Ok&feature=youtu.be
making beats with one mother.
This is brilliant, amazing work, care to share the patch details?
Thanks, let me try…
KB > MULT enables you to use different notes to shape your sounds.
MULT 1 > VCF ensures low notes or kicks play through closed filter, without noise, high notes (hihats) play with open filter and pass the noise. Mid notes blend osc and noise and yield toms and snares.
MULT 2 > VCF RES ensures high notes or high hats have more treble and sound thinner. Low notes have less resonance and therefore more bass.
NOISE > LIN FM gives you a slightly different, sharper flavour than parallel mixing osc wave and noise, and it leaves your external input unused.
Once patched, the trick is to find the right notes to generate BD (here using C2), SN (F5) and HH (B8) and tweak further settings to your liking (try note length / EG decay / vco mod, etc.) Remember you are sequencing with only one oscillator voice, so set your steps wisely.
