Sequencer/Arp Modulation
So far, I have been very happy with the Muse, but I’ve noticed some limitations in terms of modulation. It’s not as simple as taking a patch cable A to input B. As advanced as the sequencer claims to be, I’m a little disappointed that it can’t be modulated in any capacity. It’s not an option for a mod destination. Also, if I run the sequencer, it automatically sounds off the VCA, so I can’t only trigger the sequencer when I press a key. Basically, I can’t treat the sequencer the way I would on a monosynth; it’s also quite buggy when I try to change keys while the sequencer is running. My hope is that these kind of inconveniences will be ameliorated the same way the Moog One did. What are your thoughts?
