Sequence length
Hello
I have been spending the afternoon with new system
As regarding the sequence length I have been managing to cut it from say 16 to eight steps by pressing KBPS octave button and say step number 8 of 16.
That works fine and steps 9 to 16 vanish.
Does anyone know how to get them back again or even if it is possible.
I expect its a dumb question but I can’t seem to get it.
The updated Sub 37 manual says:
SET FIRST STEP/LAST STEP
To set a certain step as the sequence’s first step, press and hold the desired step button and press the > KB OCTAVE :reverse_button:>  button. To set a certain step as the sequence’s last step, press and hold the desired step button, and press the > KB OCTAVE :play_button: > button.
NOTE: > You can also > CURSOR > to the last step number displayed on the LCD and dictate a new last step using the > ▼/▲ > buttons.
I think you should just be able to set step 16 as the last step again using these instructions.
I tried that but the sequence doesn’t come back to 16 steps.
I guess once you’ve cleared a few steps that’s it they are gone.
Anyone found a way round this?
Hmm, it works fine for me here.
If I want to go back to a 16 step pattern from a lesser number I just hold down the 16th step and press the KB OCTAVE “>” button on the bottom left of the 37 and it reverts back to a 16 step pattern.
I’m beginning to wonder if my update hasn’t worked properly.
Previously when I switched on the 37 the screen came up with the number eg 1.06 when I switch on.With the new update there is no screen telling me about op sys number.Isthat standard now?
The last line of the last page in the Global menu says … M1.1.0 P1.1.0. … Maybe this is it?
I switched the 37 off to go out.When I came back I switched it on again and had a go and now all works ok.
:laughing: Amazing what taking a walk can do sometimes!
