selecting presets from top panel
I’ve previously listed this in another post - but it may well have got lost in the noise as it was quite long, so I’m listing it as a separate issue.
I have discovered some unusual responses when selecting the presets from the top panel..
If the right hand panel is chosen in the librarian, the presets can be selected by the top panel as expected (except for the ‘up’ button moving down the list and vice versa, which is counter intuitive).
If the middle panel is selected so the preset is loaded into the current slot then clicking on the up/down buttons or choosing from the drop down list doesn’t work properly… The first 10 presets can be ‘clicked through’ via the drop-down list or the buttons, but continuing through the list does not work, and the remaining presets can not be loaded via the to panel.
The list is alphabetical in the centre panel and starts with numbers then A-Z. In the box at the top the names with ‘spaces’ appear first e.g. Dorian Electra, Percuss Dub, Analogue Native Dance (all os which start with at least one space). The spaces are ignored in the panel in the centre, which is confusing, as the list appears to be different.
So, to clarify which are the first 10 that can be selected: those with spaces followed by patches with numbers. The last one that can be loaded is ‘5th in Line’
Hello Starsky,
I see there have been similar posts but just to make sure it’s not left behind, what of the above mentioned issues still happen to you when using latest 1.1.19/0.9.39 ?
Thanks in advance !
