Saving sequences from PITCH CV
I’m running a sequence from my eurorack system into the PITCH CV of the SUB 37 and I’d like to save the pitch sequence to the sub 37.
I thought that after each gate sent to the KB GATE it would input a step while in REC mode but it doesn’t seem to do anything. Is this method of programming the sequencer not possible?
Hi buzzard,
The Sub 37’s Step Sequencer stores MIDI Notes. There is no internal Pitch CV to MIDI conversion that would allow you to input MIDI Notes by sending Pitch CV. You could probably do it if you had an external CV to MIDI converter.
Of course. That makes sense. Thanks a bunch.
