I’m trying to achieve a fairly straight forward effect on a Voyager RME, but it’s not quite working as expected. I’d like to have the filter set to a random frequency with each note played. In my current attempt, these are the relevant settings:
The effect requires the trigger input for the sample and hold to be the keyboard gate, as latigid on has pointed out.
If you’re using a Voyager RME, you will need a VX-352 to break out the keyboard gate.
Further, if you just use the unmodified signal to trigger the Voyager’s filter cv input, the effect will be choppy and abrupt. For the filter frequency changes to be smooth, it requires a lag processor (as appears on the Moog CP-251).
This key-triggered s/h application appears in the original ARP Odyssey owner’s manual/patch book, specifically the Roger Powell tutorial.
I guess wrongly assumed that setting LFO Sync=KB would retrigger the sampling because it’s restarting the LFO. (Oddly, this setting actually has no effect when LFO Source = S+H. The samples just continue happening at the LFO rate, unfluenced by the KB.)
It’s a shame the synth can’t do it on its own. It’s such a fundamental patching technique, IMHO.
Anyway, I’ve just recently aquired both VX boxes, so that should do it. Of course, a soon as my RME gets back from Moog after having its analog board replaced…
