Well, since I’m often too eager getting new gear instead of getting the most outof what I’ve already got (guess I’m all alone there right? ) I thought I’d try to see what kind of “vowely” sounds I could get out of the phaser instead of buying a Murf. So.
I have the 101, 103, 104 and 241, and tried taking Env Out from 101 to Trig on the 251. Then Out 1 to Sweep In on 103. But nothing. Used the attenuators between Out 1 and Sweep In as well as between Env Out and Trig. Still no changing frequencies at the 103. If I take the 251 LFO out straight to Sweep In it reacts. I just can’t get the S&H thing to work.
I haven`t checked the manuals, but the first thing that comes into my mind is whether the generated Env is high enough to trigger the S&H. Maybe routing the Env Out through the mixer and adding some offset voltage will solve the problem. Or maybe you just need to push the 101 a bit to generate an usable Env. The attenuators will only attenuate or invert your Env out, but not add to the voltage.
If you want to explore some “vowely” sounds with your gear you could use the Env out into the 103 resonance in, or the S&H-ed 101 Env out into the lfo speed in, or lag the 101 Env out into the Sweep In.
I hope that helps. Enjoy the tweaking and don`t forget to post successful results .
Recall that there are two inputs for ‘Sweep’ and one of them must be used in 12-stage mode, controlling the second six stages via the aux out. The other sets the centre point offset for the internal LFO. Hope that helps!
Like my fellow Schweizer says, you may need a sharper trigger for the S&H. A good trick to double a voltage is to run the env into the multiple, then patch two outputs into the mixer. Output of that to the sweep in. Hope it works!
But a gate out from a midi-to-cv should do it, no? But it didn’t. Is the gate signal to short? A gate signal to Trig on the CP-251 and Out 1 to Sweep In on 103 should be right. Can’t get my head around this one. Annoying!
Just to be sure, you’d like to be able to change the S&H output level with an external trigger, right? And you don’t want to get a 10€ switch pedal but have you’re bass trigging the S&H jump, right?
Dumb suggestion maybe: try if the S&H works correctly alone, then with an external LFO trigger like the Voyager’s.
IIRC, the S&H works by default with the internal noise generator and the internal square LFO. You can see the graphics on the panel BTW.
As soon as you plug something in the IN input, the signal replaces the noise.
As soon as you plug something in the TRIG input, the signal replaces the square LFO.
So if you’re sure the default configuration is ok, then try with you envelope or another noise source sent to IN. This way, you’ll see if that jack works correctly.
Then, unplug that and try your Voyager’s LFO in the TRIG inut to see if that jack is ok.
If everuthing is running as expected, then I guess the 101’s envelope is not stiff enough (or high enough) to trig the S&H module, as suggested earlier.
It works. But neither from only the CP251 nor with Voyager Gate in does the effect on the Sweep frequency get that big. If I turn the knob for each note I play (poor mans S&H) the effect is very much in your face. But from the 251 just noticable. Even when adding and tweaking the attenuators. Hmmm.
quoting Moogmusic CP-251 instruction book, page 27:
" triggering occurs when the voltage at the TRIG jack descends through the +1 volt nominal trigger threshold ".
Both triangle and square LFO waves are provided on the CP-251.
They are sharp pulsating signals wich are going up and down through that +1 volt triggering threshold .
The ENV OUT voltage signal from the MF-101 is not the same type of signal. It is representing the “contour” of your bass line when you perform.
The bass wave contour voltage goes up when you start performing, stays probably higher than that +1 volt for a while, then, when going down
the end of the wave, it passes back that +1 voltage trigerring threshold again…maybe it is why the effect is not so much noticed when trying to trigger the S&H with that ENV OUT voltage.
Hmm gotta read that a couple of times to understand. And I use the gate signal from the Voyager (via a midi-to-cv). Just so you now. I started with the 101 Env Out.
ok, let me quote myself here: " the bass wave contour voltage goes up when you start performing, stays probably higher than that +1 volt for a
while, then, when going down the end of the wave, it passes back that +1 voltage triggering threshold again ". That’s not true, better, my english
and electronic knowledge are not good enough !
Looks like to me that there is always a voltage at the envelope as soon as you put ON the oscillators and raising them up. Along with “dynamics” on your bass performance, that voltage will vary. The ENV led is showing voltage activity happening as you perform.
I patched-in TRS cables this morning, I don’t know if what you try to get is something like that but here is the routing:
sound: B84 (Birdy bass, no alterations)
Voyager with MF-103 > MF-101 (through mixer OUT/ filter IN with insert type cable)
VX-351: KBD gate to CP-251 TRIGGER (I know you tried with MIDI-CV, my set-up isn’t)
MF-101 ENV OUT to CP-251 S&H IN
CP-251 S&H OUT 1 to CP-251 MULT IN (the one with white circle, maybe red jack nut if older ?)
1st MULT OUT to MF-101 CUTOFF jack
2nd MULT OUT to MF-103 SWEEP IN jack
3rd MULT OUT to MF-103 SWEEP jack
Knobs settings:
MF-101:
amount > 0
mix > 5
cutoff > around 10 o’clock
resonance > start with 6,5 then you might raise it while fine-ajusting to your taste later
switches > smooth & 2-poles
MF-103:
lfo > kill
rate > 32
sweep > 5
switches > lo & 12 stages
Watch your levels when you fine-ajust both resonances…What it sounds is that there is a second “vowel” pitch singing voice along the bass. Start with the A left of middle C (4th notes, “allegro”, 132bpm): A>G>F>E then back to A again.Watch the MF-101 ENV led while you perform : dimmer > low “vowels” , brighther > high “vowels”.
