Running Sub Phatty Osc through Slim Phatty Envelopes
Is it possible to run ones oscillators through the others envelopes via CV?
Hi Tomas.
Even simpler: Sub Phatty audio out → Slim Phatty audio in.
To be sure the Sub is sending out the raw, un-enveloped sound, set its envelopes to a rectangular shape, i.e. A=0, D=0, S=Max R=Max.
Finally, be sure to trigger both of them simultaneously, either via MIDI or CV.
Thanks! i thought for some reason the audio in was only for the filter.
Actually, the audio in signal will flow exactly the same way as the internal oscillators signal.
That is exactly what i have been doing. Running mopho osc through sub 37. Works perfectly to gain extra oscillators. Only thing is the mopho oscillators are a little brighter than the moogs own.
Midi out from sub 37 to mopho, audio out from mopho to audio in on sub 37.
