So I just hooked up the minitaur to my Elektron key, using CV to trigger gate and pitch. All is good there.
However, when I use an arpeggiator on the minitaur track, the range sometimes goes beyond the minitaur’s capability and the notes get jumbled up and it sounds like an LFO. Will this damage my Minitaur unit ? I imagine, the Elektron Key is sending voltages higher than +5V on those high octave range arps. Usually a quick patch reset ( go up one patch then come back ) fixes the whacky sounds. Just want to make sure I don’t accidentally hurt the unit. Any thoughts comments appreciated.
The CV jack is v/oct and is converted to v/hz inside the MT. v/hz has a limited upper range for electronic reasons. You probably hit the upper limit. You won’t damage it but try to stay away from that limit.
after later firmware updates your minitaur should just play any notes beyond it’s range within it’s upper octave
earlier versions just repeated the top note, which might be triggering what you described
you’re right Dan
the same bug bit me today when i tried running it off a random generating CV patch instead of MIDI
i wonder if a firmware update can fix it quicker than i can figure out how to attenuate that random patch
I am not a wizard in the software programming world, but I’d bet a lot of money that the note wrap trick is achieved simply by remapping higher MIDI Notes back down to MIDI Notes within the MInitaur’s highest octave. If this is true, there’s no simple way to replicate that trick in the analog CV part of the Minitaur.
