I just found a way to use the after touch in a musical way to change the pitch in one user assignable direction and amount.
- Select the sound you like to use
- On the Pedal Modulation Bus set:
Source: On
Destination: Pitch
Shaping: On
Amount: 0
- Switch the Glide in the left hand section off
- Pot Mapping #1:
SRC Pressure
Dest. Pedal Amt
Direction Normal
Amount 100%
- Pot Mapping #2:
SRC Glide Rate
Dest. Mod2
Direction Normal
Amount 100%
- Now the GLIDE knob will set the inverval you get with max after touch.
I use the value 130 on the GLIDE knob for a whole step positive bending via after touch.
Of cause you need a proper after touch. So you need a newer Voyager, or a Voyager with the after touch fix by Moog or Lintronic (I use the later now) or a RME Voyager with a remote after touch keyboard.
I love the Voyager for its new features we got with each new update Rudi Linhard builds. Thanks !
