Rogue power supply..
Can I replace this with something off the shelf? Don’t have time to get it repaired, but need to use the synth tomorrow.
Heeelp…
Probably not but there are a few new build replacement PSU’s for Taurus 2 pedals floating around ebay at the moment that might do the trick.
Put the question out to MC or Kevin Lightner for a definitive answer . . guys?
Mal
I have 'em in stock, but no way we could get one to him by tomorrow.
Look for ebay account: married_with_patchcords when time isn’t a concern.
Also, all Rogue owners should be aware that there’s a bit of a design flaw with this type of plug Moog chose.
The tip of the plug can short to the ring when it’s inserted or removed.
It can short out the adaptor if it’s already plugged into the wall.
So, always plug your supply into your Rogue or T2 first, then plug the adaptor into the wall. Reverse the order when unplugging.
We include a note about this with all power adaptor sales, but it’s good to know to avoid needing a new one in the first place.
According to the schemo at http://www.physicsenterprises.andrews.edu/diy_archive/manuals/moog/rogue/rogue7sm.gif the wall wart is 24VAC 200ma. You may have to solder the right plug for the Rogue.
And yes that steenking thing can blow thanks to that stupid plug.
