RME - Some random questions
Didn´t want to start 3 threads so I started this instead! :smiley:
  1. My RME´s display contrast every time I power it up. I have to adjust it every time. Also it says something about bank D at startup, is this the known issue where the OS 3.5 update hasn´t worked?
  2. The screws for the rack ears are missing, what size and length are those? In metric mm if possible.
  3. The wood panel on the front, is it possible to remove it? I wanna make a custom wood rack that covers the front, sides and maybe extend above to hold hold a CP-251 and a VX-352 and maybe 3x Moogerfoogers so it´ll look like a mini arcade came console! :smiley:
You can get the right contrast when you reload the operating system bank D.
Here you can get the 3.5 version:
http://www.moogmusic.com/sites/default/files/voyager_3_5_rme_web.zip
If you need help with the MIDI transfer take a look here:
http://forum.moogmusic.com/viewtopic.php?f=2&t=22525
Have fun,
Rudi
Thanks man!
Questions 2 & 3, anyone? :slight_smile:
You might be best emailing Moog support instead of asking on the forum to get answers to your other questions.
