I’m using a m-audio midi keyboard to control the Voyager RME and a slim phatty. It works, almost fine. But it seems that I cannot achieve the fast “last key” triggering I know from the Voyager keyboard-version ( every new key press triggers a new note). Can I select this function somewhere or is the m-audio keyboard (oxygen
not capable for that?
The slim phatty is connected with the midi out from the RME. The m-audio midi out is connected with the RME midi in-port.
Make sure that the “EDIT trigger mode” is set to “multi trigger” in the “Edit functions” menu.
That might be it.
thank you for the tip. ( and sorry for the late response). unfortunatele it seems to be not the answer. anyway thank you very much for your help. i’ll try it again.
all the best
niko
