Ring Mod into Murf
hi
i just bought a moog murf and i use it on a fender rhodes with a moog ring also. i wanted to know if its possible to trigger the murf with the lfo of the ring…or something like this…
thanks!!
Well, depending on what you mean by “trigger”, the answer is probably yes. But the good news about the MF line is that you can just try it and see, right? You can run the LFO out from the the 102 into pretty much any CV input on any other pedal. Experimentation is encouraged.
Michael Glaviano
The moogerfoogers with envelope followers (101, 105) can only be triggered by incoming audio. So if you like you can use the envelope out from a 101 to dynamically control more CV gear, like a mix control on the MuRF, or whatever. Like Michael said, just give it a go!
