Ribbon Controller question
I “found” a model 1150 ribbon controller-which was in storage for years, but can’t figure out how to hook it up to either my mini moog or sonic 6.
It has a 2 position switch, one for the mini, and one for the sonic 6.
But the huge connector with 8 pins doesn’t match any connection on my mini or sonic 6. They all have 6 pin accessory connetions.
Is some type of an adaptor needed for this connection?
TIA
Larry Benigno
What you need is the Universal Cable Assembly Accessory 994-041983-001.
This assembly consisted of an 8 pin female cable connector on one end and a 6 pin male cinch connector, a 2 pin male cinch connector and two 1/4 inch phone plugs on the other.
Since it has not been available for a while, here is the pin-out on the 8 pin connector:
    • Voltage
  1. GND
    • Voltage
  2. S. Trigger
  3. Gnd
  4. V. Trigger
  5. Aux Out
  6. Pitch Out
Here is the pin-out on the 6 pin cinch connector:
    • Voltage
  1. GND
    • Voltage
  2. N.C. (No Connection)
  3. N.C.
  4. V. Trigger
The S. Trigger and Gnd goes to the 2 pin cinch male connector and Pitch & Gnd and Aux & GND each goes to it’s own 1/4 inch phone plug.
Hope this helps.
That helps indeed!
I thank you.
Larry B
