Reverb mix?
Hello, new Moog One owner here..
I know I can adjust the send to increase the signal going to the effect, but I’m still limited it seems on the %wet signal I can send to the output. How can I increase the master effects reverb mix or wet signal? I’d be happy if I can even just assign the wet master effects signal to the sub outs.
thanks
Figured it out for anyone interested.
Master Effects apparently is 100% wet, not mixed. You can control the effective mix by altering the Synth (1/2/3) level in the VCA ‘more’ page. Sending Synth volume to zero give you a 100% wet signal provided the send level is 100%
