Reseting the Mother-32
I used my Mother-32 with my K2600 to play leads, and then I tried to set up midi pitch bend, and after that, the Mother-32 no longer took the midi signal. I thought that my attempt to get pitch bend going had some how interfered with the midi functions, so I’d like to clear every thing and start all the options over. Any advice? Thanks.
Hi mburgh,
My first guess would be that you’ve accidentally changed the MIDI Receive Channel of the MOTHER-32.
I’ll brainstorm other possibilities if you confirm that it’s not the MIDI Channel.
That’s good advice. I’ll give it a try.
Worked like a charm. Thanks ever so much.
