RELEASE VERSION: Quick Update 0.9.55 / 1.1.28
We’ve found a crash which happened while renaming a preset while Search function was active. The Search code has been changed, so please pay attention to this function in particular.
We’re still heading a final 1.0.0 in a day or two.
There were some fixes made which required a new version, please download and install:
Windows:
http://www.moogconnect.net/downloads/sub37/Moog_Sub_37_Editor-0.9.55-WINDOWS.zip
OSX:
http://www.moogconnect.net/downloads/sub37/Moog_Sub_37_Editor-0.9.55-OSX.zip
Firmware:
http://www.moogconnect.net/downloads/sub37/Sub_37_Firmware_v1_1_28.zip
Thanks !
ZIP seems corrupted…
There seems to be a packaging issue which I’m trying target. For now I edited the original post with direct links to each component. This should work.
Still won’t un-zip for me on OS X 10.9.5
R.
Yep, sorry about that. Just use the direct download links for now.
1.1.28 firmware updater still not opening
FW update opened OK for me just now, from the link above.
(And a great new look for the OS X installer! Nice!)
Direct OS X link works fine for me now, thanks … :smiley:
R.
Hi…
The corrupt issue comes, when Gill is sending a new link for us and uploading the new file…We try to download this file…but it went not complete through The servers from Moog…they are slow..???..Takes time…
I had this problem sometime…Just wait a bit and try downloading again and the file will be OK.
regards Luloop.
Not really. I generally wait for the upload to complete before posting. I’ve reuploaded today while the link was still active, but the links are changed now.
One thing changed for me when I updated the Moog Sub 37 firmware, before I even installed the editor. Previously, my Sub 37 would echo MIDI clock from another device so long as the option was enabled in the menus. However, upon updating, this now only works while the arp/seq SYNC button is engaged. The MIDI clock carried both ways (SYNC on or off) until this update, I’m pretty sure.
“echo MIDI” definitely should not be affected by any other settings. I just tested here on latest firmware and I confirm that if “Echo USB” is set to “USB” then clock is passed from USB IN to USB OUT regardless whether Arp SYNC is on or off. I also tested Echo USB to DIN and it worked as expected. (I didn’t have a handy way to send DIN clock into the Sub 37 here at the moment, but it should work exactly the same as USB and none of this code has changed in many versions)
One thing, any time you update firmware it restores global settings to default… and global default setting for MIDI->CLOCK OPTIONS->SEND CLOCK is “Arp”, which means that the Sub will output clock (of its own, not echoed) when the arp is running. Default for Echo is OFF so this would have been automatically turned off after updating firmware unless you turned it back on yourself.
I think this may explain the confusion. It seems to me things are working as they should.
Thanks, I’ll check my settings when I get home from work and report back.
every time I save a preset it saves as the init name in the editor
if i look in to the folder on pc were the presets are saved ,it has the right name there
This is not normal. Can you describe a reproducible scenario which will hopefully let us see it locally ? we are a minute before compiling 1.0.0.
Thanks.
I have just saved as I have with all the older editors.
I loaded the init preset,
worked on the sound I wanted on the sub37
clicked save as on the editor
picked the location I wanted to save it
put in a name for the perset and clicked save
but the editor & sub37 display shows still as init, but in the files on my pc it shows the correct name I gave the preset
so I just tried this out a few time saving different copy’s of some presets in the editor and it always just saves as what it was called before I renamed it
mesa
OK I understand now.
Well, the behavior was changed in 0.9.55 so the preset name is not depended on the file name.
This behavior seems more correct as you sometimes would like to save presets under different file names, or use a file name which doesn’t carry the exact preset name (for example, in case the preset name includes spaces so it appears in two rows on the Sub 37 display, but the file name uses only one space char).
Is this the case ?
No that’s not the case. this is a really big problem actually I can not use the editor for saving sounds as I can not rename/name any presets
If I save a preset I can not Name it any different than what it was before.
So I made 5 different sounds yesterday from the init patch
Lets say I named these
bass 1
bass 2
bass 3
bass 4
bass 5
What I see in the editor/sub37 display is
init
init
init
init
init
ok so then I tried changing a preset, I used a preset from the factory presets 2D SPACE
PAD 1
PAD 2
PAD 3
PAD 4
PAD 5
2D SPACE
2D SPACE
2D SPACE
2D SPACE
2D SPACE
But when I looked in the files on my PC there all named correct
MESA
Salvator the developer has sent you an email, will you be able to help him target this issue?
I sent him an email back about connecting on Teamveiwer but didn’t get a reply and then i had to do some work in the studio.
I am free now to get on teamveiwer if that is good for him
MESA
