RELEASE CANDIDATE: 0.9.42 / 1.1.23
Please see release candidate as Sub 37 Editor 0.9.42 and firmware 1.1.23:
http://www.moogconnect.net/downloads/sub37/Sub_37_Editor_Pre-Release_v0_9_42.zip
Firmware 1.1.23:
http://www.moogconnect.net/downloads/sub37/Sub_37_Firmware_v1_1_23.zip
The package includes moog USB driver 2.23.0.
Both 3.30.0 and 2.23.0 work with Windows 7, but the older one (v2.23.0) doesn’t require some users to go through a possibly-difficult Windows Update process in order to read the driver signature. The new driver uses a newer security protocol (SHA-2) which wasn’t originally supported for driver installation on Win 7.
Windows 7 users, please:
  • Uninstall Moog USB Driver, in Control Panel
  • Under “C:\Windows\System32\Drivers” , Delete files moogusbmidi_x64.sys and moogusbmidiks_x64
  • Install MoogMusic_MIDI_DriverSetup_v2.23.0.exe and restart
All users should upgrade firmware to latest version.
Fixes in this version:
  • Fix #529 Preset buttons do not light up
  • Fix #321 Certain preset cannot be copied to a custom folder although its name is valid
  • Redraw properly transparent background of Librarian
  • Fix #531 Send Preset hangs without a net connection
  • Fix for CV mapping and Per Preset (pack/unpack/checkformat)
  • Some Protools specifics fix (especially hang due to MIDI input, potential fix for Amos default settings)
  • Fix dragging error on KeySlider
Release is planned to the end of this week, please use and test it as much as you can and post anything unusual.
Thanks all for your contribution !
Link isn’t working. I can’t click on or copy the link
Link not working.
Funny…Before it was working. Have just downloaded the new firmware for one hour or so.
And Now not anymore!!!
Yes I can confirm this
regards Luloop
Yep, bad link.
Additionally, if I copy and paste the link into a new browser window, and replace the occurrences of “%2f” with a “/”, Firefox posts a warning that the Moogconnect server certificate (CA) is invalid.
Sounds like Moog is having IT problems today :smiley:
BTW, Gil, any harm in leaving the 3.30.0 USB driver in Windows 7? Mine is working fine.
Thanks,
Apologizes, please try now.
3.30.0 is supported and is safe to use, but we need to know that 2.23.0 works well too,
therefore it is preferred that you use Windows 7 with 2.23.0.
If you insist working with 3.30.0 it’s ok, we need to confirm that too !
Thanks !
Ive tried to use the firmware updater but it flashed the eprom but didnt proceed to the next part, now installed says unknown and available 1.1.22 but the updater is now preparing to install but does nothing. Could you advise how to correct this, I do have midiox but not sure how to manually send the code to the sub 37
i found your manual install sheet but midiox says not enough memory despite configuring as suggested.
anyway its stuck at 324 of 768.
if someone can pm me and assist via telephone that would be great
managed to retrive the situation and now at 1.1.22 however the firmware updater does not work in win 10 64 bit it flashes the eeprom then gets stuck
Hi Gil,
I am using the 2.23.0 already some day and It is working fine under Windows 7.
No problems till now.
Thanks ..
regards Luloop
0.9.42 Installer:
  • Mac OS X Permission issue regarding the user’s library folder seems to be solved with the this Installer
  • The Factory Presets are now missing
Yay!
I am compiling final presets for the v1.0.0 build today. There will be some new ones in addition to the factory set. :slight_smile:
I have updated firmware to v1.1.23;
re-packed in the original download (link in first post)
or here is a direct link to just the new firmware:
fixed a regression from previous betas; firmware was not updating editor if Init Preset or Panel Mode functions were activated on the Sub 37.
These actions on the hardware (press PANEL for panel mode, or hold PANEL to load Init Preset) now update the state of the Editor to match.
This is intended to be the last change before release, provided nothing else is seriously broken.
Download and installation of the 1.1.22 firmware and Sub37 Editor worked flawlessly !
BTW, I’m using Windows 7-64, the Moog 3.30.0 USB MIDI driver and performed the updates through a USB 3.0 hub ! Que Judas Priest - “Breakin’ the Law, Breakin’ the Law” :laughing:
No problems with the 1.1.23 installation either !
Hi pb21,
I also had problems everytime using MidiOx, it crashes regularly. This tool seems to have a massive timing problem. It’s good to monitor MIDI messages, but not to update firmware and additionally it’s painfully slow.
I highly recommend the Elektron C6 SysEx tool. It is still availlable for free under
https://www.elektron.se/support/?connection=accessories
scroll down to “downloads” and choose “C6 SysEx Manager”.
When you start it, make sure your MIDI port is connected (under “configure”).
The use is quite simple:
  • Choose “Load” and load the four SysEx files, you received with the Moog firmware (subfolder “manual install”, files “sub37 xx.xx step1” to “… step4”)
  • the files appear in the window of C6, select the first “…step1” file and press “Send” (Sub37 will delete the current firmware)
  • wait until the display of the Sub37 shows “… ready to receive firmware” (or similar)
  • in C6 then select the 2nd file “… step2” and press “Send” again (the mainboard of Sub37 will be updated, this takes just a few minutes)
  • after the update, the Sub will reboot and the display shows a normal state
  • in C6 select the 3rd file “… step3” and press “Send” again (the panel board will be cleared)
  • in C6 select the 4th file “… step4” and press “Send” again (the panel will be updated. Be patient. The display shows nothing. This takes a longer time than step2, then the Synth reboots again - your Sub37 is ready)
This procedure takes much less time than with MIDIOx and less time than the Moog updater too. It never crashes here. I’m using WinXP, but I’m sure it works with Win7 or later too.
cheers and much success,
Bernard
Hi, sorry for the trouble! I sent you a PM. Please reply or email me (amos at moogmusic dot com) if you are still having difficulty.
Regarding the MIDI-Ox settings, I just checked and the manual install instructions don’t actually recommend the buffer settings I prefer.
I will update the instructions. My recommended settings are:
Size = 1024 Bytes
Num = 256.
Updated to Firmware 1.1.23 and did a couple of tests using the Panel and switching around between Presets and Panel Mode. Seems to work pretty well. However, I don’t fully understand how the Panel Buffer works. It seems to be overwritten every time I select a Preset either from the Editor or from the Hardware. Not sure whether that’s on purpose.
This Version doesn´t work for me.
After recording a midi track in Cubase (or NI Maschine…) and switching to another program from the editor, it doesn´t work anymore.
Control from Sub37 to Editor: works fine / Controlling any Parameter from Editor to Sub37: doesn´t work
Sorry for my bad english
P.S.: Last Working Version (without this bug) is 0.9.39
thanks erolok!
We did some more testing and fixing; this should be working in upcoming v0.9.43.
Uninstalled 3.30.0 and installed 2.23.0 and everything is working smooth! Man I love this editor it looks so great.
Installed the latest 1.1.23 and editor 0.9.42. Both installed fine. Will test in the build below tonight and report any bugs!
