Fix #321 Certain preset cannot be copied to a custom folder although its name is valid
Fix #512 Renaming preset from the top menu doesn’t work
Fix #508 VST plugin’s window in cubase cannot be resized
add support to sysex notification for Program change by 3rd party
Fix #507 Window inside a window appears in Cubase when loading a saved project
Workaround for VST setParameter loop in Ableton
Fix #503: Empty pop up + app hangs on OSX
Fix weird sending of set CC mapping when boot
The intention is being able to release the Editor by the end of next week, which means it’s very much important for us to have your feedback regarding this version.
Please install, check and report stability, automation, DAW compatibility, connection performance, preset system issues and anything else that you find important enough.
Whatever is not critical level will be delayed to the updates made after first version is released.
Thank you all for your great job and contribution !
This is mostly for the convenience of new testers, so they can get all the documentation… editor and firmware files are same as in the individual links above.
I would like to know if this is the normal behavior in Reaper.
After making some automation the MIDI button stays red all the time and the Sub 37 front panel doesn’t work. Even if I disarm all the tracks. If I want to use the Sub 37 panel again I have to bypass the Editor, then the MIDI button turns off. Is this OK?
I was getting the same behavior last night but i am in ableton on the build listed in my signature. I thought is was a midi loop on my end but I couldn’t find it in the settings
not true, if it’s a MIDI loop between Editor and Sub 37 directly. The DAW wouldn’t have anything to do with that.
Looking into this ASAP. Can one of you run MIDI Monitor to see what messages are flying back and forth?
Hi Gil and Amos,
installation went fine under OS X 10.11.3. Standalone and vst Plugin are working (tested with ableton live 9.6). Also the patch renaming works. No probs with automation.
I just played around with the “Rhythmic 5th filtration”. there I noticed that the editor doesnt show the changing lights of the filter slope correctly. It just stands still.
“After making some automation the MIDI button stays red all the time and the Sub 37 front panel doesn’t work. Even if I disarm all the tracks. If I want to use the Sub 37 panel again I have to bypass the Editor, then the MIDI button turns off.”
Thanks for checking.
