I have a reissue model D. My ideal setup would be:
Synth with local control off > midi out into Ableton live > Ableton midi track using the model D as a keyboard/midi to the model D > audio from synth to my interface.
The reasoning for treating the keyboard and synth separately, is to use Ableton’s arpeggiator/midi scales/etc and to record midi clips. I know I can record midi clips without turning local control off, but using the midi arpeggiator with local turned on creates a less than desirable real-time experience.
Here’s where things are hanging up.
With local control off - I can record a clip but not hear the synth. If I play the clip back, I CAN hear the synth. So I know that the midi connections are correct, or it wouldn’t properly record or playback. IT JUST ISN"T SENDING THROUGH IN REAL TIME. and I can’t hear the synth while I record. It’s madness.
I even tried to bypass Ableton all together, and just connect the midi out of the synth to the midi input of the synth, and I get no sound.
So what I can tell is that with local control off, it’s somehow cancelling out the incoming midi signal.
To recap. With local control off, I can record midi from the keyboard, and send midi to the synth, but I can’t do both at the same time?
that does not work because the local off implementation in the mini reissue is fishy . however there are modifications on the market which do a great leapfrog in terms of midi for the mini .
I finally was able to get the new “keyboard scan” pcb that Moog sold me ($82). No change to the issue. If I have ableton taking midi FROM the synth, with midi local off, and processing the midi data (ableton native arpeggiator) and sending the midi BACK to the synth, I don’t hear the arpeggiator (even though I can see the midi out activity light flashing the arp rate while I hold the keys down. If I do everything the same way, but use any other midi keyboard in the studio to play the Arpeggiator, the D triggers via the Arp exactly how it should.
How to use the Model-D Reissue as a master keyboard in a DAW MIDI setup. R.Meurer 240326
Here are the steps:
Global Settings: Set MIDI Local Off
• Hold down the highest three black keys (F#3, G#3, A#3) while turning on the power.
Legato Triggering Power-On Commands: Set Multi-Trigger On
• Hold the D Major chord (D3, F#3, A3) while turning on the power.
Note Priority Power-On Commands: Set Last Note Priority
• Hold the C Major chord (C3, E3, G3) while turning on the power.
Gate Source Power-On Commands: Set Gate Source to External, MIDI, and Local Keys (All)
• Hold down F2 and C3 simultaneously while turning on the power.
The format for a Note Off message (using status byte 0x80) is typically:
0x80, nn, vv, where nn represents the note number and vv represents the velocity (or release velocity in this case).
The format for a Note On message with velocity set to zero (which effectively serves as a Note Off message) would be: 0x90, nn, 00, where nn represents the note number.
the model-D keyboard is sending Note Off messages using the format
0x80, nn, vv instead of the more conventional 0x90, nn, 00.
As long as the receiving MIDI device properly interprets the messages,
either method should work.
