REDUCE note range of Minitaur (filter midi notes)
Hi!
Is it possible somewhere in the minitaur setup to reduce the range of the instrument? I.e. don’t want it to respond to midi notes above a certain value (I want to use only the bottom half of a midi keyboard to play bass, while using the top half to control other sounds.
Thanks a lot :slight_smile:
  • Connor
No.
And I non of my synths got such a function, unless is features some multitimbral options.
That’s what MIDI controllers are supposed to do. And just because a keyboard can output MIDI doesn’t make it a “MIDI controller”, it may not have split functions. I sold a digital piano because its capability as a MIDI controller were woefully inadequate.
no, it’s not possible. You should try a digital piano.
