Recording XY Pad Midi Messages
Just woundering how to record movements on the XY pad of the voyager to my sequencer. At the moment I am currently using Logic Platnium and can record most of the control messages from the voyager. But, for some reason or other when I play the XY the messages are not played back in my midi recording.
Is there some type of trick to make this avaiable?
Has anyone else acheived this?
Regards,
Joam
Hi Joam! When you go into Edit mode and select T.S. Desitnations (X, Y, A) you must select a MIDI CTRL No. to transmit midi messages. I leave mine off since I don’t use the TS to send midi. Once you select a No. you should be able to record the messages.
monads
