Recording button presses on the MP
Hello,
I’m just about to splash out the MP. I had one question. I want to send 4 different speeds of ramp modulation, to get the wobble bass sound on a Voyager.
I wondered, can I record the button presses into a sequencer? So when I stomp on one of the 4 buttons, it’s recorded and then plays back?
Does that make sense? In other word, can I trigger the buttons using a midi sequencer so they then send CV?
Thanks in advance,
Best wishes
Jasper
Sort of, but I don’t think so…
Let me explain. You want to have a channel configured for Gate | Momentary and yes, you can certainly record that. On v2.0 of the pedal firmware (which is what I have installed so the answer may vary if something newer has more capabilities), you can send a Midi note (any value), or send the momentary On/Off for a CC # on a given channel. The On Off are the typically accepted 0 and something above 64, or 127.
What would be handy would be if you could set the actual value to be sent along with the CC # and even better, have it be a 14 bit #. If you check your Taurus manual, you’ll see specific values for the various waveforms so you’ll need to select these via each.
Send a personal msg to Amos (if he doesn’t see this first) and suggest it. I think I may have as I had some issues trying to get a T-Rex replica delay pedal to receive certain values some time ago.
