Is it possible to record the position of the modwheel when i record a sequence on the sub37?
I thought that is was possible according to the manual but I can’t figure out how to do it… (I don’t hear the expected results when I play back te sequence…)
you need also to set the programmable mod source = “SEQ MOD” … it’s not quite like it’s playing back the mod wheel directly, more like the mod wheel is a data-entry device for recording a generic mod-value per step. You can then assign that mod-value per step to all sorts of things on playback.
