Recommend an analog flanger?
Anyone? At the moment I use a Boss BF-3, but would like something a little less sterile, but still phat and able to handle Bass frequencies.
Anyone used a 104 as a flange? Got any settings?
Thankyou all
Check out the tzf.
http://www.foxroxelectronics.com/
WOW! That guitar sounds ALIVE! A bit pricey, but sounds worth it.
Anyone tried Bel Electronics Flangers?
Or Lovetone “?” (flange with no name). I know they cost, like, a thousand dollars, but you never know.
The minimum delay on the (original) 104 is 40ms, not short enough for flanging.
i have the foxrox tzf. great versatile flanger and very expressive with expression pedals.
I just bought the Lovetone ? and Ring Stinger, I’ll describe the flanger for you when they arrive in 2-9 days if you want.
Look at the harmony central reviews for it too. From what I can tell after reading those it seems to be more an analog modulation multi effect pedal than a specialized flanger though. So if you’re looking for a more traditional flanging sound I’d definately say the TZF takes the cake.
Opeth, that would be cool. Do you now have a 102 also? Could you compare the two when they arrive? (gotta love the photo-theremin CV :slight_smile: )
When it comes to effects, I think the quirkier and crazier the better.
Don’t emulate; reinvent!
The Ring Stinger is going to be my first ring mod, so I can’t really do a first hand comparison, but I’ll give it a bit of a review along with the ?.
I agree completely about wierd and interesting effects, too bad Lovetone are gone for “the forseeable future”, but hey, we still have Moog :slight_smile: .
If you can find one, I can heartily recommend the Electro Harmonix Electric Mistress. I used to have one of the original pedals and it was the maddest flanger ever. Also had a notch filter setting which is handy for those Kraftwerk ringy snares.
Sadly, my Mistress blew up one day. Cue smoke and tears. :cry:
ADA Flanger all the way and it has CV inputs. I miss mine.
I highly recommend the Systech rack flangers (4000 and 7012) if you can find one. Voltage Controlled, great sound..i use one along with MF-103 and MAM RS-3 for CV controlled modulation. the BEL flangers are wonderful as well, but harder to find and more expensive in my experience.
Well, I love my Ibanez FL9, is very liquid sounding. I have the original version that was released in the 80’s, but its my understanding that Ibanez just reissused the pedal. You can probably find the original Ibanez FL9 on ebay for a good price.
Laters…
Yep, have tried an original FL-9, very cool, but tended to sound very thin when used on bass frequencies. Save the pennies and go for a “?” I reckon!!!
So I finally got the Lovetones today, this is what I’ve gathered so far…
The ? is very very nice. Like many people said I’ve found it can go from phasing (but it’s very subtle phasing), to flanging, to chorus, aswell as psuedo reverb and a bit of slapback too (both somewhat noisy), plus tremolo, PLUS ring mod-ish sounds. Some of the modulation sounds can be very bizarre, examples I’ve found so far is a very vocal sounding chorus/flange, and also a very beautiful but very out of tune chorus, plus it can be tweaked to have a very weird background (or very loud) pulse which can simulate a heartbeat oddly enough. Normal sounding effects are just as easy (or hard, depending on whether you read and understand the manual) to get as bizarre effects. Sound quality is pristine, unless you tweak the Manual control past 3 o’clock, then it’s get a little lofi and noisy, but some very un-subtle effects are around this point!
Self occillation is where is get very amusing, you can get anything from pulsing bass, to a hilarious simulation of someone whining, or ooooing, siren sounds are possible too. Very useful and versatile effect.
The Ring Stinger is perhaps too weird for most, very hard to get anything remotely normal (impossible perhaps?), but some very interesting sounds are possible, it can get very high pitched. Insect noise is easy to get, aswell as the classic ringmod weirdness and very useable sounds are possible if you use the blend/mix. There also this weird thing I think they call gating
(not sure/don’t remember though), where a note or chord will repeat and decay much like a delay BUT if you let go of the note it will disappear instantly.
If you want anything clean, sorry that’s not possible with the Ring Stinger, it’s pretty filthy and apparently that’s the nature of the circuitry. They also make a specific reference to the Minimoog and how to get the Ring Stinger plugged in!
Hope that helps.
Thank’s for that; I’ll save my pennies (unless they run out, then it would be a modular instead :wink:).
older thread…
but the Flanger Hoax is great
For whoever posted about the Bel Flanger, I have one that I would probably part with, as I don’t use Flangers much. The Bel Flanger is from the 70s, I believe, and is definitely the best sounding Flanger I’ve ever heard and it has CV input and LFO output. It doesn’t sound anything like a flanger pedal, it’s something different.. There are pictures of it at Modezero.com:
http://www.modezero.com/bf20.htm
Check your PM, eric
